free simple box designs.
since your kinda bored I will give you something to do. For 2 DD9515s max size 49.5 wide 23 deep 22 tall. This is to fit in a Suburban with 3rd row. Subs up port up but against back. say 4 cubes each sub
16 square inches of port area per cubic foot of box volume, make the port 18-22.5 inches deep.
120 sq inches of port area 4x30 right around 8 cubes after subs port and 45's
45s are 4.5x30(inside port) and 5.75x46(front wall)
top and bottom cutouts are 47.5x23 3 total------
---- 2 will be used to double up on the baffle. with port centered Left to right. cutout will need to be made for port. centered left to right. starting .75 inches front back of box. and ending 4.75 inches. being 30 inches wide.
left and right are 22.25x19.75
back wall is 19.75x46
front wall is doubled up outer wall being 19.75x47.5 inner wall being 19.75x46
port sides are 4.75x19.75
port wall is 14.75x30
smaller 45 goes against back wall inside port. larger goes against front wall and bottom(opposite port.)
I have a 10" Oz Matrix Elite dvc 2ohm sub and going to build a new box. It's going in a 1994 Mustang convertible. The space I have available is about 34" wide 13" deep and 14" high in the front and 7" tall in the back. I'll be powering it with a PG Tantrum 300.2 running mono which puts out about 350 watts @ 4ohm mono. If someone could give me the dimensions for a sealed box and the cubic ft I would appreciate it. Would a ported box work better?
Thanks
Sweet drawing on my double 15 box. Alright i have another for you to try. Single 15 20" tall 24" wide 24" deep. Port back sub up. I want the port to go the width of the box. tuned at 47hz.
all measurments are outside dim.
Did you seriously just request two free box designs?
marcotheclepto
marcotheclepto
United States
ktraughb
