free simple box designs.
marcotheclepto
give me some dimensions you can work with and desired tuning size et cetera. will be simple slot ported or sealed and come with 3D drawing of it.
playing with google sketchup need something to practice on //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i can help with cut sheets also thanks.
Edit: finished all requests posted. if you have further requests send them via PM. can check thread for my work. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
2.5 @ 35Hz with the port exit in the center of the box on the back side, sub facing front of box //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Oh yea 36" wide or under is the only measurement that really matters
starting it now, 12" im assuming?
1 18" 50w X 22h X 14d. Sub forward port forward tuned to around 35 or lower
any particular cubic footage you want?
3 cubes @ 31 hz
Sub up Port back
28" Wide 14" high 35" deep
Single 15" driver getting fed 1000 watts =]
your next //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
12" cutout
2.5cubes @ 32hz
13.5 height
31 width (max)
?? depth can work with this
double baffle, no extra supports needed inside
port back, sub back (possible to do sub up port back without conflict?)
___________________________________________________________
Sub up port back. Single 15. Dims, 40 wide, 16.5 tall, 17 deep. about 4 cubes after port displacement. 37 hz with 60+ in of port area. Not all that simple lo.l I think I have a design but would like a backup source
for you sir.
25w 20 deep 14 tall.
port is 2.5x12.5
first section should be 4 inches next 9.25 and then 9 inches
left and right walls are 18.5x12.5
front wall is 12.5x 25
real left wall is 11.25x12.5
rear right wall is 11.25x12.5
top is 25x20
You da man. Thanks bud!
haha no problem. any donations are welcome //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif need rca monies, if you have a roundover tool would be nice to do like a .25" roundover on the ends of the port.
how about a 1'x1' sealed box for a 4" MONSTER...lol jk, good luck with the sketchup dude, very fun program and handy once you learn how it works.
serious yes and extremely lazy...
plus that was a little side order next to the main one i was looking to get //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It's a sealed box, so "after displacement" can only mean sub displacement since there is no port. You didn't even include what sub you're using so he would know the displacement of it.
12x12x18" internal will give you 1.5 cubes, so external dimensions will be 13.5x13.5x19.5" if you use 3/4" MDF
knock yourself out.
marcotheclepto
marcotheclepto
United States
ktraughb
