free simple box designs.
3 cubes @ 31 hz
Sub up Port back
28" Wide 14" high 35" deep
Single 15" driver getting fed 1000 watts =]
does the 14" include height for sub? or do i need to accomodate for it?
edit: assuming it accounts for sub/sub excursion. got box designed.
box is 22w 13t and 31d
all walls are 11.5 inches tall
left is 22x11.5
right is 21.25x11.5
back wall is 24x11.5
front is 29.5x11.5
port 1 is 16.25x11.5
port 2 is 15x11.5
baffle is 31x22
be sure to take into account the ports location when cutting your baffle.... shouldnt be in the way if you put sub close to corner
for you sir.
25w 20 deep 14 tall.
port is 2.5x12.5
first section should be 4 inches next 9.25 and then 9 inches
left and right walls are 18.5x12.5
front wall is 12.5x 25
real left wall is 11.25x12.5
rear right wall is 11.25x12.5
top is 25x20
I'm happy that you're learning and practicing, but I need to tell you that this isn't a very efficient port design. You need the port to be as free flowing as possible, and there is no reason whatsoever to have two bends when they aren't necessary. More importantly, if it can be avoided, you never want to vent out against a wall (where a wall forces the air out aka the exit is at 90 degrees to the port versus the port terminating facing the air aka in line with the port) as doing so can cause a good amount of compression and you'll get port loading. You don't want that. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I read that 3 times and still don't quite get it. Could you just do some quick paint pictures to kinda show me what you mean?
It's a sealed box, so "after displacement" can only mean sub displacement since there is no port. You didn't even include what sub you're using so he would know the displacement of it.
12x12x18" internal will give you 1.5 cubes, so external dimensions will be 13.5x13.5x19.5" if you use 3/4" MDF
knock yourself out.
great thnx
true, i wasnt entirely sure how to tackle centering the port and avoiding that. ill prolly redo it if i have time. thanks for your input. much appreciated. i welcome all constructive criticism.
12" cutout
2.5cubes @ 32hz
13.5 height
31 width (max)
?? depth can work with this
double baffle, no extra supports needed inside
port back, sub back (possible to do sub up port back without conflict?)
___________________________________________________________
sub up would definately be easier. what kind of vehicle? suv or hatch should be fine.
Two identical length ports, both running along the rear baffle of the enclosure. The ideal one will end with the port wall parallel to the rear baffle and will be ported out the side of the enclosure so that the air goes straight out. The non-ideal one will have the port wall parallel to the rear baffle, BUT, the port terminates with the rear baffle, meaning that the air makes a 90 degree turn up against the side of the enclosure, and it's that bend that forces the air out.
I didn't even read that it was part of the criteria, so never mind. I can't figure out another way to do it myself //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
i think i caan pull it off with 1 turn, haha but will need to redo all dimensions.... how deep can it go? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Back of a station wagon so 2' or 3'. Sub could also face up if needed.
does the port have to be top to bottom? or can it be longways on the bottom of box? but still centered? i can make that work. will be like a "rectagular air duct" running along the "ground"
got a new design, too tired to upload now. will tomorrow...
car DVD player online store
Car DVD GPS Player can play MP4/ DivX/ XviD/ DVD/ CD /VCD / CD/ CD-R/ CD-RW / MP3 with GPS TV FM RDS DVB-T Bluetooth SD Card Amplifier can show the best route to your destination can help you save a lot of time ,especail when you in strange city
Chrysler 300C Car DVD Player with GPS Navigation System 3D Screen Steering wheel control
Product Description:
Touch screen 5.0 Inch 2-DIN TFT LCD Monitor with DVD Player/TV/4*45 amplifier/AM/FM/GPS Built-in/CDC/USB/SD Card
3D menu Operation
ipod ready
DVD/VCD/MP3/MP4/DIVX/CD/CD-R/CD-RW/DVD-RW Formats
Dimmer function for night driving
DVD/VCD/CD changer control interface
Multi-channel auto EQ
Auto reverse function when parking
Car clock function
AUX input
Bluetooth build-in
Warranty:One year
marcotheclepto
marcotheclepto
United States
ktraughb
