Free Box designs.
each chamber is 3.85^3 @35hz 1" MDF
thanks alot for your help do appreciate it, i forgot to let you know that i will be
inverting the subs, that would changes the chambers volume, if its not to much to
ask can you redo the skitch,you could cut down on the deepth since the subs volume would be out of the count.
again thank you for your effort and help
i actually just sent in my donation of 8bucks. guess thats better than nothin. another request.
single 12" memphis m3 30"w x 14"h x 17"d tuned 32hz. slot ports on both sides. want the box to look symmetrical.
thanks
thanks alot for your help do appreciate it, i forgot to let you know that i will beinverting the subs, that would changes the chambers volume, if its not to much to
The box ^3 is without sub displacement. So it wouldn't matter if you inverted the subs. But if you want i can re do the box.
one 12" Alpine type R in a single cab ford ranger.. there isnt much room. The sub magnet has to stick out backwards through the middle of the 2 seats. The front board has to be flush with the angle of the seats.( You have 10" on the bottom and 4" on the top) Im not sure if that makes sense?
Height 23"
Bottom width 10"
top width 4"
Length 53"
Just seeing if you could design one for me for a 9510g. DD recommends around 1.25-1.5 ported to 40hz so i would go with that. Tallest the box could be is 14 inches just to be on the safe side and 36 inches wide and 16 back to play with probably. Port and sub firing back.
Any donation is good! Whatever you think some of the 3d designs take about 30mins to 4hours.
6.256^3 w/o port at 32hz lots of port area!
now i see it i think id rather have a more rectangular port.. but no taller than the sub itself. so if you could adjust, thatd be koo
thanks
nvm.. if i just adjust the sides and keep the port area the same it would be the same as the original right?
i have a request for 2 12's l7 ported i have bout 34 inches in lenght and 18 in width and 20-25 in height the only thing is the front of the box can only be about 14 inches wide and getting bigger towards the back of the box to 18 inches this is going to sit where the back center console is in a king ranch supercrew i am going to take out the console
thanks
All the sides are measured in 3/4 MDF 34" is the width =)
I always add the 3/4 measurements into the box design or 1" or 1/2" Depends on the person but i always do 3/4 unless the customer wants something different.
The box you design me, Reg Ported box 4.42^3 real @32hz
Is it before displacement or after displacement? For the FI Q 15". It might be to big, for the enclosure. If so, can you design another ported enclosure in the range of 3.5-4cf.
thanks for your quick respond, if its not to much to ask,can you redo the box with these dimentions ( since its going to be an inverted setup )
w 46 x h 17.5 x d 19 tuned@35
thank you for your help
Calutate around 4.05^3 sub area
rcnshoe
VW Pimp
rcnshoe
Next to you.
roarzorz
NorthFramingham
    Jun 30, 2026
