ford transit 2020 sync 3 diagram
  • 2
gabrieltransit2020
canada
hello !
i bought a ford transit 2020 and I want to upgrade the sync 3 with a subwoofer.
I search on the web for the color diagram and I didn't see anything for the sync 3.
Can someone help me with this wire ?
Thanks you very much !!!!!
478
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
gabrieltransit2020
gabrieltransit2020
canada
gabrieltransit2020
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
