For the last time, PLEASE: clipping does NOT blow speakers/subwoofers
I do have one question though as I have never tested this in a controlled environment.
If you clip the shit out of your inputs to the amp, how much does this effect the output assuming output was set without clipping? Will it then clip the outputs as well? Or will it be more likely to clip the outputs?
There is nothing wrong with trying to learn. These days with access to the internet its actually much easier to dispell these so called myths that we all grew up hearing. I think we can all agree there is a good deal of misinformation regarding car audio.
A lot of it is taught right here. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif This is where most of us "learned" that clipping kills speakers.
In all seriousness, I'm glad this thread came about. It's been a little while since I've learned anything that was truly worthwhile.
Garbage in, garbage out, I would think.
so a 100w amp can blow a BTl?
The cheap Jensen amp you're referring to could NEVER blow a BTL...it's all about putting too much power to the speaker. It's obvious that a 100 watt amp that's pushing 150-200 when clipping the hell out of it is NOT going to blow a sub that's rated for 2-3k.
Now let's say you have the 150 clipped watts going to you tweeter that's only rated to handle 50 watts...that's a case when the speaker would easily be blown.
Yes, but thats like saying its not big deal to run your cars engine without water, as long as it doesnt get overheated. Because its the heat that causes the failure, not the lack of water.
I think its pretty well accepted that too much power can cause driver failure. But telling people that clipping can cause failure is just another way of saying clipping can cause more power then expected to the sub.
Also, one thing that you are not taking into account is that with a clipped signal, the voicecoil stays in the position longer then the normal excursion, causing more heat to build up in that section of the coil.
10000% agreeed here.
Heres 1.. During full clip, Direct AC can result from the output wave becoming fully "Squared off" As a result not only will the coil stay in the top and bottom stroke longer, the chances of the coil being pulled left to right will also become a increased risk. Also known as "Coil Rock". This can be damaging as well. Both to the driver and the power source.
PV Audio
The Vision of Sound
PV Audio
Indy
mcsoul
