Fixable or a loss???
  • 7
oxsign
No Affiliation
6,046
34
Orlando, FL
On the drive home today I made a call via BT. When I was done I tapped the "X" to close and this is what the screen did......
Might either be a loose connection in there somewhere or the screen is borked. I guess your only way to find out is to tear it open, or if there is still a warranty on it send it in.
Looks like a loose ribbon cable. I repair tv's and that's what happens to some of them. Shouldn't be too hard of a fix unless it's something else. With volume off do you hear any noise from the LCD?
That's what I thought too, especially if he's had it long enough to not have a warranty anymore I wouldn't be surprised if a ribbon cable wiggled loose. Tear it open and check it out OP, can't hurt!
I think I'll give it a try today after work. Your the 3rd person that's said that same thing today, lol. Thx for the advice.
---------- Post added at 01:26 PM ---------- Previous post was at 01:25 PM ----------
I have 2 pieces left if you want one I need to know today
I'm gonna mess with this one and see what comes of it. Thank you for looking into that for my.
No crack that can be felt or seen on the surface.
The LCD could be cracked on the inside and you wouldn't feel it and in some cases wouldn't see it (The LCD is going to be so dark it'd be hard to see) but in this case... it looks like a ribbon cable.
So I took the face off yesterday to see if I can fix it. I disconnected & reconnected all the ribbons and it didn't fix it. So I'm just gonna order another HU. I'll fix this one later on and sell it unless someone wants to buy it as is. It sux cause it still works great!!!!! Just can't see half the stuff, lol.
Well if yu want one of the b stock 5500 I have 2 left. But they will be got by today
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
Hello! are you found the cause? I have similar problem. Sound like Sh*t bass :/
Nice find. Generally always an issue at a Break /Spliced area. Ikeep approx. 4-6 inches of wiring on each side of a main Fuse to refresh to Clean...
13
The next time it happens check the voltage directly at the Boss radio. If it has 12v on both the red and yellow wires and the black wire is...
629
oxsign
No Affiliation
oxsign
Orlando, FL
mylows10
    Apr 28, 2024
    Apr 28, 2024
