First Time Trying This 4 Mids to a 1 channel amp @ 1 ohm
  • 4
vpersaud93
Hey guys, I've never tried this with car audio but I want to try to (4) Crescendo 10" 8 ohms each Midrange speakers to 1 Taramps HD5000.1 Amplifier.
So 4 mids at 300 watts rms - 8 ohms parallel should give me 1 ohm 2400 watts per speaker. 2400 x 4 = 9600 watts.
I want to use the Taramps HD 5000.1 amp which outputs 6000 watts rms at 13.8 volts.
What do you guys think, any suggestions?
What about left and right stereo?
Are you planning a mono soundstage?
4 - 8 ohm speakers would be a final load of 2 ohms not 1 ohm
How do you plan on running 4 - 10" drivers for a soundstage?
EDIT - also what is your electrical setup that you plan / want to run 5,000 watts for a front stage? I would assume you plan to run at least that much to the substage so what electrical do you have to support 1,000 amps of power draw?
Welcome to the site. This is the classifieds where we sell things. All that template text that you had to delete should have suggested as much.
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
453
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
vpersaud93
vpersaud93
New Jersey
ciaonzo
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
