First system
Asian69
I just got 2 Kenwood KFC-W3011s from crutchfield. 2 12s in a sealed box with a kenwood amp that is 900W RMS @ 2 ohms and 1800 max.
I had the cheapest wiring kit from wal-mart. the power wire is 12 gauge. Just replaced it this weekend. It hit hard and very sloppy for about a day. Then it got cleaner and the volume dropped alot. Way worse than the 12 gauge.
My new power wire is a 4 gauge. I used only the power wire.
I did not install the new grounding or the capacitor it came with. Should I try the new ground? Or just go get an 8 gauge kit
I just got 2 Kenwood KFC-W3011s from crutchfield. 2 12s in a sealed box with a kenwood amp that is 900W RMS @ 2 ohms and 1800 max. I had the cheapest wiring kit from wal-mart. the power wire is 12 gauge. Just replaced it this weekend. It hit hard and very sloppy for about a day. Then it got cleaner and the volume dropped alot. Way worse than the 12 gauge.
LMAO //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
stick the cap up yo ass with some KY and the bass will come back.....
lol //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
First try a new ground, clean it up and make sure it is on the car chassis and not something connected to the chassis. Also, imo i would change your rca's - spend a little more cash on these.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
92
579
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
Asian69
Asian69
Arkansas
Paddywad
    May 24, 2024
    May 23, 2024
