Jsound
What type of material do you use to fill in a hole after you have ran your wires through it? Help please.. Thanks in advance
Sent from my SM-G960U using Tapatalk
to "fill" the hole or what to put in the hole to protect the wire thats going thru said hole?What type of material do you use to fill in a hole after you have ran your wires through it? Help please.. Thanks in advance
i wasnt sure if you were looking to fill the hole after removing the wire or what you were referring to. Silicon is probably going to be your best bet. Only really needed on the engine side to waterproof and itll adhere to the wire. Pretty permanent tho.I know about grommet... But I've seen someone use a black material to kinda fill in the grommet so the wire doesn't slide
Sounds like a plan... Thanks for advicei wasnt sure if you were looking to fill the hole after removing the wire or what you were referring to. Silicon is probably going to be your best bet. Only really needed on the engine side to waterproof and itll adhere to the wire. Pretty permanent tho.
Yes. I use on both sides even if i use a rubber grommet. I still seal with Silicone.i wasnt sure if you were looking to fill the hole after removing the wire or what you were referring to. Silicon is probably going to be your best bet. Only really needed on the engine side to waterproof and itll adhere to the wire. Pretty permanent tho.
I use these, waterproof, No silicon needed.Yes. I use on both sides even if i use a rubber grommet. I still seal with Silicone.
