Finished With my Build, PICS of Progression!!!!!
mustbenu
these are all the wires and connectors i used.
heres a closeup of te knukonceptz battery terminal i choose
fitting the 0 to 4 guage reducers into the amp
THE BIG 3
The SUB SI MAG 15
Sub wired
The box 2.7^3 sealed 3/4 MDF
The Trunk
Test Fitting
Finished Product... Everthing was wrapped in headliner foam the vinyl was strecthed over it. Amp is tuned with a DMM and everything sounds great very loud and very clean.
im sure with the next few months i will add things to it or maybe change some of it.. but for now im happy. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Looks good; Maybe some push-in grommets on the cables, and fix the wrinkle under the box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Looks clean, but it almost seems as if you should have made the box a little bit wider to fit more cleanly in between the wheel wells. Also, the Christmas wrapping-type style on the box doesn't fit the look of a sub box. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thats awesome man! it looks really good, and myself pretty much have that same setup. But mine is a 12" claw. im using the same amp, my box will prolly be around that big gross, but will be ported to 32 hz.
yeah ill hide the wires... but the box wrapping job is done perfect and done like that on purpose. maybe it doesnt look right in the picture but it looks perfect in person.
so i got bored after 2 hours with my setup so i added 2 more subs and extended the amp and hid the wires //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
mustbenu
mustbenu
new jersey
tommyk90
