If thats the box your subs are in then that is one of your problems. First you need to fix your amp settings the way they have already been mentioned. Then, find someone on here that can build you a real box thatll let those puppies pound. Just fyi prefab boxes **** @$$.I thought thats what I gave? Kicker TC-10![]()
If you have clicking from your door speakers then check all of your wires between the "(Receiver->Fuse Box->(Component)+(Speaker)" you explained above for any ***** places in the wires. Also, make sure your reciever is grounded properly.alright, cool. thanks guys. This gives me something to work off of.
im going to try out those settings after work later and post back. The clicking sound sounds like it comes from the speakers, not the subs, but I'll double check later on that too. There's no RCA's hooked to the speakers. The speakers are wired up directly to the receiver after being split in the fuse box to the tweeters (Receiver->Fuse Box->(Component)+(Speaker). The only RCA cables I use is from the receiver to the amp (which only outputs to the subs).
thanks again. hopefully i'll find out more later.
It doesnt matter if their running off the headunit and just the bass has the amp going to it, this is how a setup i had was, when the rcas touched behinf the headunit it made one of my rear speakers constantly pop. so double check this cus sounds like the same thing.alright, cool. thanks guys. This gives me something to work off of.
this can be true but not always, like im saying it wasnt even all my speakers just a loud pooping noise from one of the rears and as soon as i unplugged the rcas it stoped, you should make sure its not coming from the subs then unplug the rcas, if it stops then thats your problem.if the clicking is coming from your full range speakers then you need to turn on/ up the high pass filter (hpf)
did it play music and you could just hear the popping on quiet parts of a song? did the popping get louder as the volume was turned up?It doesnt matter if their running off the headunit and just the bass has the amp going to it, this is how a setup i had was, when the rcas touched behinf the headunit it made one of my rear speakers constantly pop. so double check this cus sounds like the same thing.
it would play music but with static and popping was the same loudness i believe. lol but dont help me my problem is already solved, i fixed it by isolating my rcas by wrapping elctrical tape around the exposed metal sides, fixed it 100%did it play music and you could just hear the popping on quiet parts of a song? did the popping get louder as the volume was turned up?
lol I was asking because I am having a similar issue. I'll try wrapping them in tape todayit would play music but with static and popping was the same loudness i believe. lol but dont help me my problem is already solved, i fixed it by isolating my rcas by wrapping elctrical tape around the exposed metal sides, fixed it 100%
lol oh no prob, how doe the back of your headunit look does the rcas plug directly into the back of the HU or does the back of the HU have cords coming out that dangle with RCA outputs? mine had the cords and when they dangled down under the dash they touched.lol I was asking because I am having a similar issue. I'll try wrapping them in tape today
lolslol I was asking because I am having a similar issue. I'll try wrapping them in tape today
