Final Subwoofer Choices
mikes81
Okay so I have been thinking of set-ups to replace my single CSS SDX10 subwoofer powered by a Rockford Fosgate t500.1bd. The two options I am considering are:
1) Fi 12" Q ported in a 2.0-2.25 ft^2 ported box
2) Shiva-X2 12", but I am not sure on which enclosure would be good for musical in car response.
DIYCable.com : Intro » Home » Exodus Subwoofers »
The new set-up will be powered by the bridged rear channels of a t1000.4 and will receive about 736 watts. The Shiva-X2 seems to be a more SQ oriented subwoofer, but the Fi Q is also marketed as a SQ subwoofer, so my real issue in deciding which subwoofer to purchase is will the Fi Q really have a noticeable increase in output, and can the Shiva-X2 reach a good output level with loud deep bass in a reasonable sized enclosure.
I would try the shiva just to be different. I have seen no one with any exodus subs. I feel like they are going to become the forum boner. They look more like a home theater sub. But they have a very low Fs and higher then average xmax
Shiva is a true sq driver where he q is a SQL driver. It sounds decent but nothing special nif the shiva can give u the output I want it's easily the better driver
with ur power I would go shiva because the Q will benefit from 1000+ watts
q won't be louder than the shiva off the same power
if U go shiva it's great sealed ported or IB
Idk they are both somewhat SQ drivers, and I kind of want to try something out of the ordinary. I don't see too many people trying to run exodus subwoofers, and does anyone have any recommendation for a ~2.0 ft^2 box for the shiva I realize that it would probably take a not so ordinary box design to make it sound good in car.
is this your t5001bd? you would be supprised what it can really do @ 1ohm and lower........
watermark.php
mikes81
mikes81
San Francisco, CA
akheathen
