Fiberglass vs. Wood
  • 3
Fiberglass is easier to form curves, shapes & build into less than square areas and you can also paint or gelcoat the finished box. Wood is easier & faster to work with but you are limited to angles in building. As for the sound difference, boxes made Properly for the peticular application with either material will produce the same results.Most Fiberglass boxes are made with both materials anyway.
um....no now really.....mabey an original frame that is removed, but even at that more people use wire frames for kicks and such. Fiberglass just allows you to take care of those curves, no huge differences in the sound of them, but a few minor ones to exist.
I thought we were talking about boxes
I haven't seen too many fiberglass boxes with no wood used in the fabrication at all.
I have seen plenty...i guess in only sub boxes you see a lot of wood baffles mounted to glass......other than that the whole idea of figerglass is to go where wood cant //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
3K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
The only inside treatment that actually makes any difference is sealing all the cracks with silicone or the like to keep the enclosure from...
7
If they weigh 23 pounds then they will last longer than all of us combined. The term "Brick Shitthouse" comes to mind.
33
3K
thumpin s10
thumpin s10
Cantonment, Florida
evo2k3
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
