fiberglass sub box dilemna..help me...*PICS*
lotas
Well i dont have to go into great detail but basically my depth isnt clearing 100%. The sub is flush on the top but not on the bottom. Its a little more than a 1/4" off. The only I option I have (i think) is to build this bottom half of the sub ring up to the sub and mount it.
What could I do? I tried just fiberglassing the shit out of the bottom half but it didnt make much of a difference. Is there anything I can do other than building half of a MDF ring that decreases in width as it gets towards the sides?
Can I just glob a whole bunch of liquid nails on it, compact it down, glob again, comact down so its a solid layer? Any other ideas?
thanks guys.
here are some pics.
By the way: Not looking for any criticism on my fiberglassing, however "constructive" it may be //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif just looking for some help on the topic. Thanks again.
well the reason I didnt want to keep glassing was because Im almost out of resin and I really dont want to go spend another $15, ive already bought two gallons and a 32oz can...thats why I was wondering if there was any alternative.
buckshot, its not a matter of the size of the ring, its that the back end of the sub is hitting the back wall of the enclosure.
How far would I have to stretch that fabric? Would I have to do it just like I did it with the ring+dowels? That would be a lot of glasing.
I really dont care if the sub sticks out a lot from the enclosure, so I might just make a 1/4" ring and attach it to the glass now, glass over it with a couple layers and then mount.
yea, 1\4" more isnt gonna cut it.
if your sub has a pole vent, it should be at least 1" from the backwall of the box.
you should start getting imaginative.
next time, mount the sub before you glass //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
i'd make the 1/4 inch ring first, and then build the kitty hair up against that so you can mount the sub on a flat surface.
//content.invisioncic.com/y282845/emoticons/iagree.gif.15d6c075ee8d3913ba26866d06993068.gif except i'd give myself a little more room to work with, and like TPABlazer said, you'll need room for the vent, so go with at least 1/2". It might not look as good, but it's better than your other options.
the pole vent does have room, you guys arent picturing this right. Its an XXX, so its an edge of the magnet thats hitting pretty high up on the back...the pole vent is smack dab in the middle, as you guys know, so it has at least 1/2" before the back, possibly more and a couple inches before the bottom, so I'd say thats better than you are picturing.
I dont think i can use a full ring because it wouldnt make any difference than it is now. Only half of the ring is off, the top half is fine.
Is there anything I can glass over or glass in to give it height? For instance could I cut little thin pieces of MDF and glass them on the existing ring?
thanks for the help guys, Im appreciating it.
well how bad does it hit..maybe sand down the inside of the box a bit.....if not just gunna have to make another ring and glass it on...dont see much options...always test fit things in the future!
yeah I shouldve test fitted. I was just really upset because I had to throw out two perfectly good MDF boxes before having to resort to glass.
Plus I did everything myself...Im not sure how I wouldve tested the sub, i mean as you know its 55lbs, dont think my wooden dowel + hot glue would hold it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Still, shouldve found a way to do it...but gotta learn from mistakes!
I dunno, I measured, but I guess not good enough.
It is the side of the magnet that is hitting to back wall, not the end, if that clears it up.
What would make this a bad idea?:
Spreading on some body filler/putty type substance on the bottom half ring, then sanding if needed and glassing over that? Thanks guys.
lotas
lotas
Washington
TrlcKed_OuT
    Jun 20, 2026
    Jun 20, 2026
