Fiberglass box building
SteelKiller
Anyone do their own? Thinking a sealed 10 or dual sealed 10's under the back seat of my Ram. I have never worked with fiberglass before but am willing to give it a shot if it means better sq for less to or a little more $$#!!!! Is it possible to do a 4th order or ??? In fiberglass under a seat? Thinking out loud!!! I need more bass and my truck is not the best candidate for this!!!
I'm not a fan because the finished box is never as rigid as using 100% wood. It might look better and fit odd shapes easier but performance wise it won't be as good as wood.
You want the sub's enclosure to be as close to using 100% concrete as possible. Super hard with zero resonances.
Fiberglass, Kevlar, carbon fiber has a lot of flex to it unless you add plywood or sandwiched core material. You can go very thick with it, then you add weight and a lot of stench.
SteelKiller
SteelKiller
Portland
Flabum
