FI SSD 12" Subwoofer For sale
amedeuce
:crap:
1,825
CA
Selling my FI car audio 12" SSD Subwoofer. This has the Copper coils, with the BP option. I've tried to include those in the pics
Sub is in awesome condition as is the rest of the stuff I'm selling
Not sure what a good price for this would be but I'll start it at $175.00 plus shipping in US
The RMS is 1000w. The t/s are close to what's listed on the ficaraudio site. I'll try to find more specific specifications with the options this one has but for now here is an explanation of the copper coils and BP option.
Copper coil (now standard) – The copper coil is a heavier coil and adds mass to the moving assembly. In comparison to the stock coil, or the flatwound coil, this has the smoothest transitions musically speaking. It is less likely to peak, and is a better overall sub for more Sound Quality based daily drivers. This coil is now STANDARD on the SSD.
BP Power - This option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack. All of these features increase power handling from 200-500 Watts depending on the application.
Contacted Scott at FiCarAudio and the current specs for the SSD can be used AND with the options this subwoofer has the RMS is 1200w
SSD12
DUAL 1 | DUAL 2
Fs: 30.1 Hz | 30.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 7.65 | 7.65
Qes: .37 | .37
Qts: .36 | .36
Mms: 248g | 248g
Cms: 0.11mm/N | 0.11mm/N
Sd: 480cm^2 | 480cm^2
Vas: 36.5 l | 36.5 l
Spl: 86.1dB 1W/1m | 86.1dB 1W/1m
Bl: 13.1 N/A | 18.7 N/A
Xmax: 20mm
Rms: 1000W
Sealed box: .7-1.2 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
Glad they stepped up and replaced it! I honestly would have thought it was super petty if they didn’t just swap it out for you still being under...
6
Buck has been my go to since I got into builds, currently he’s unavailable and hopefully back at his passion soon (for privacy I’ll leave it at...
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
648
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
amedeuce
:crap:
amedeuce
CA
giltyler
winkychevelle
    May 24, 2024
