Fi Q vs. DC Level 4
Bumpin' Goalie
Magic 8 Ball
Looking for good response and SQL. Will be in a ported box no larger than 1.8cubes tuned to ~33hz. Receiving 1200rms
Q12
DUAL 1 | DUAL 2
Fs: 28.4 Hz | 27.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 05.39 | 5.63
Qes: .49 | .48
Qts: .45 | .44
Mms: 211g | 231g
Cms: 0.15mm/N | 0.15mm/N
Sd: 481cm^2 | 481cm^2
Vas: 48.3 l | 48.3 l
Spl: 85.4dB 1W/1m | 84.8dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .8-1.5 cuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
DC LEVEL 4 12
Mounting Depth
6.75"
Mounting Hole Diameter
11"
Motor Width
7.75"
Weight
32.5lbs
VC Diameter
3"
Magnet Weight
28.5lbs
Power Handling RMS/Peak
1000/2000
Impedance
D 2ohm
Sd
494.00 cm²
Vas
66.60 L
Cms
1.95e-04 m/N
Mms
173.08 g
Fs
27.4 Hz
Bl
16.15
Re
3.60 ohm
Le
4.02 mH
Qms
5.13
Qes
0.42
Qts
0.39
Xmax
23.5 mm
Sensitivity
87.0 dB
Suggested Ported
1.5³ ft
Suggested SPL Ported
2³ ft
Also, willing to consider Fi BL, and other woofers under 300$
Thanks.
josh your ava is re? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
thats cause i still got re, when i get the lvl 4 i will change it.//content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif
Both are excellent drivers, and would both work very well off that power...however, I would suggest the DC based on exp with the LVL 4 18" I had, plus the fact you were going to use a 1.8ft3 box for either 12.
That looks to be a little small for the Q IMO, but would be fine for the DC. I had my LVL 4 18" in 5.5ft3 net tuned to 32hz off 1200w and it was perfect.
fasfocus' date=' to your ears, how would you describe the differences? thanks a bunch[/quote']
minimal. the DC seems to move more air, like I can feel my hair move alot when it hits. the Fi definitely sounds great and hits hard but I don't feel as much air movement. mirror shakes like hell with both. I wish I could give you a more exact assesment but I have not metered either and I was told that the Q would perform a little better in a box tuned closer to 30hz instead of 35hz. honestly i don't believe that 4-5hz difference at that frequency is going to make that significant of a difference. just to fill you in on box and amp, it's ~3.5 cubes net with a 6" aero port tuned to ~35hz being pushed by a Hifonics Txi1508.
Bumpin' Goalie
Magic 8 Ball
Bumpin' Goalie
TN & Travel
Bumpin' Goalie
