Buck
little alien on campus
do these hit all bass notes good? and is there any way that fi can make it a triple stacked magnet to increase the power handling? thanks
depends on the box....sounds like you want a sealed boxdo these hit all bass notes good? and is there any way that fi can make it a triple stacked magnet to increase the power handling? thanks
I have a 15Q in a 3.2 tuned to about 32 and it sounds pretty good, going to build a lil bigger box and tune it to around 35 though. Add the bp option if you want more power handling.do these hit all bass notes good? and is there any way that fi can make it a triple stacked magnet to increase the power handling? thanks
thanks, do you know how much more power handling you get with the bp option?I have a 15Q in a 3.2 tuned to about 32 and it sounds pretty good, going to build a lil bigger box and tune it to around 35 though. Add the bp option if you want more power handling.
see i am planning to run one off of an ed nine.1, which is 1200w@12.5v and about 1400w@14vYou could probably get alot more help on fi's forum but im pretty sure with the bp option it raises the rms to aroun 1200-1300, know alot of people that run 1500 to their q's but make sure u have a good electrical and set ur gains right.
Think you should be fine with the Q and the bp option long as u set ur gains correctly.see i am planning to run one off of an ed nine.1, which is 1200w@12.5v and about 1400w@14v
