AQ HDC318-A in 14.4 cuft trunk using IB?
mcsoul
such is life
Would an AQ HDC318-A in 14.4 cuft trunk using IB work?
VAS 109 ltr (3.85 cubic feet) trunk is 3.7 times the size.
QES .5
QTS .464
FS 31 Hz
rest of the specs:
http://www.audioque.com/aq/HDCSeries.htm
What would this do to the power handling, I was
thinking it may handle an AQ 1200d this way?
Will it work as IB, or will my trunk act like a big leaky
sealed enclosure?
The Car is a 2004 nissan Altima, the trunk and rear deck actually
do not look to bad in terms of IB, it's almost ideal from what I can see.
Just seal off the 6x9 ports and 2 little holes, and mount some layered
mdf sheets behind the seats, right against the ledge with some kind
of gastketing.
I know, I know try it and see. I just want to make sure the numbers look
right to people with IB experience.
Infinite baffle. When there is no actual enclosure, just a wall that seperates the air in the front from the air in the back. Usually you need 3-4 times the VAS, and I think I've got that.
well if you have enough room to acompany this method
i say go for it cause i want to a IB :p
and for the AMP just get the 2200 if you have the money. If not find something used. If not just get a 1200.
But yes 1200 will power it just not like a 2200
Infinite baffle reduces the power handling of the woofer substantially I believe.
Anyone who has done or calculated IB before?
Edit:
Not a bad idea.
mcsoul
such is life
mcsoul
dfw
mcsoul
