Fi Q questions
Gixxsta04
Cant decide which size Q i should get. It is going in an '01 Chevy Silverado regular cab, so there is not much room. I have taken out the center seat and I now have about 13 inches between the driver and passenger seats. Not sure how I am going to build the box yet. Would I be better off firing the sub up, down, forward, backward or angled? Will a single 10'' be sufficient for this small amount of space, or should I try to cram a 12" in there? If there is not enough room to fit a big enough volume box between the seats I am thinking about making a T shaped box and stealing some airspace from behind the seats. BTW this will be a sealed enclosure, I am going for as much SQ as possible. Should I get the dual or single voice coil?
oh, I thought the 1 and 2 stood for svc or dvc. So should I go with 1 or 2 ohm? Sorry I'm a newb.
Like I said I can probably get as much airspace as I need depending on how I design the box. If needed I will run a box all the way across the back wall(behind the seats)and extend it out between the middle of the driver and passenger seats. The box will have a T shape.
Gixxsta04
Gixxsta04
St. Louis, MO
bose301s
