Fi Q 12 Bandpass Problems!!
tizzle2008
Beatn Down
I had 80inches design this for me cause my other box was said to be too big but after it was built my old one sounded better any reason why
The one i built today only i had to cut around the port an slide half inside cause i have a blow thru and it was hitting my bench seat.... and i inverted the sub subs also still makes a slappin noise as it did in my old box just doesnt get as loud
80inches designed it an i know he knows bandpass but something happened
My old one 2.5 sealed 4 ported port 8x9 3inches long
any help solving this is greatly appicated whether i need another design or whatever i just want lows no slappin noise an loud in one box not to hard i just cant do math for bandpasses
Thanks,
Teddy
it has 2 be the sub...cuz i designed the box much smaller and ur still getting slap noises
the rear is 1.07 cubes playing into 1.79cubes now as far as output make the port bigger to 54 square inches(9high x 6wide) and that should work...but it will raise the tuning freq
i made it 36square inches so u can have decent low end..cuz it was tuned lower
80
im sure it is the sub but what bout that guy that said make the rear chamber 3-4 cubes i just want it back loud again the volume is half what it used to be. . . . and bout the sub what do i do to fix it send it back??
its not under the spider but it does have velt like material behind the sub. . . . now everything on the sub looks and feels normal but it doesnt play anything?? Like it stopped workin! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif any help
is the amp working? could of burned up the voice coils on the woofer?
RCA's. could be a number of things. Take a Digital Multi meter to it and see what ohm it is reading. If it shows up 0 ohm or some funky off the wall ohm number then its more than likely a blown woofer.
sounds like the sub was going ...as soon as u said it was slapping in the previous box and now u switch boxes and the problem is still there
its definitly the sub....send it to fi and im sure they will take care of u
80
tizzle2008
Beatn Down
tizzle2008
Orange, TX
tizzle2008
