lilmaniac2
Ask Me about SI Mag V4!
I think imma order some moofers, havent decided what yet tho.
From http://www.soundsolutionsaudio.com/forum/index.php?showtopic=12012
Along the lines of the BL promo we finished building up the parts we had for the X series and will be offering them in pairs until they are gone (as a thanks to those that have helped us turn 1 year old).
(2) 10" X series subs $150 shipped
(2)12" X series subs $160 shipped
We can offer deeper discounts for 5 or more subs as well. We built up about 200 12s and 150 10s from old motor stock (when we discontinued them at the beginning of the year) and will be blwing them out to make room for more current line products.
To place an order, send an email to Orders@FiCarAudio.com for Credit/debit card transactions with your name, zipcode, phone number, as well as what you want to order. For straight Paypal orders, please send payments to Sales@FiCarAudio.com with your name, address, phone, as well as what you are ordering.
Specs are below:
10 DUAL 4
Fs: 25.9 Hz
3.9 Ohms/coil
Qms: 3.90
Qes: .35
Qts: .32
110g
: 0.34mm/N
Sd: 310cm^2
Vas: 45.7 l
Spl: 85.4dB 1W/1m
Bl: 20 N/A
Xmax: 16mm
Rms: 300W
Sealed box: .5-.8cuft
Ported box: .9-1.5cuft
Sub OD: 11.0
Cut ID: 9.25
Mounting depth: 5.25
Displacement: .07cuft
12 DUAL 4
Fs: 25.7 Hz
Re: 3.9 Ohms/coil
Qms: 4.01
Qes: .38
Qts: .35
Mms: 120g
Cms: 3.2mm/N
Sd: 480cm^2
Vas: 104.1 l
Spl: 88.6dB 1W/1m
Bl: 20.0 N/A
Xmax: 16mm
Rms: 300W
Sealed box: .9-1.3 cuft
Ported box: 1.6-2.2 cuft
Sub OD: 12.500
Cut ID: 11.125
Mounting depth: 5.750
Displacement: 0.10cuft
Specs are below:
10 DUAL 4
Fs: 25.9 Hz
3.9 Ohms/coil
Qms: 3.90
Qes: .35
Qts: .32
110g
: 0.34mm/N
Sd: 310cm^2
Vas: 45.7 l
Spl: 85.4dB 1W/1m
Bl: 20 N/A
Xmax: 16mm
Rms: 300W
Sub OD: 11.0
Cut ID: 9.25
12 DUAL 4
Fs: 25.7 Hz
Re: 3.9 Ohms/coil
Qms: 4.01
Qes: .38
Qts: .35
Mms: 120g
Cms: 3.2mm/N
Sd: 480cm^2
Vas: 104.1 l
Spl: 88.6dB 1W/1m
Bl: 20.0 N/A
Xmax: 16mm
Rms: 300W
Sub OD: 12.500
Cut ID: 11.125
