few questions.
Lil_KB
ok, i'm gonna be running two xx hercs pretty soon. this is my first multi-amp setup. i have questions.
1. Should i strap them or just use RCA Y-splitters and run them seperately?
2. If i did strap them, what impedance could i strap them to with 2 dual 4 ohm subs? i was planning on running them seperately at 2 ohms to each sub.
3. how exactly do i strap the amps?
If you have two subs and two amps, the easiest approach would be to run one amp to each sub. For a couple of reasons: easier to wire everything correctly, and easier to troubleshoot if a problem ever presents itself. I am not too keen on strapping amps, so i cannot help you much there. Just my $.02. Good luck!
Lil_KB
Lil_KB
Louisiana
geowick07
