Few Questions
mini-goog
The amp im going to buys Specs
Code:
Bandwidth 10Hz – 50kHz
Signal to Noise >95dB
Fuse Rating 4 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 240Hz @ 24 dB / octave
HP Variable Crossover 40 Hz – 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz – 55Hz @ 18dB / octave
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.06%
Dimensions D 65.5mm L 468mm H 276mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
600 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
900 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
1250 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
14.4 Volt Power Output Specifications
840 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
1250 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
1600 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
Linked Power Ratings @ 14.4VDC
2850 Watts RMS Linked @ 4 Ohms
3400 Watts RMS Linked @ 2 Ohms
What does linked power mean?
Whats would the rms be at 1ohm?
What would you expect to pay for this/ whats another amp with similar specs?
Code:
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
"Brand Name" Amplifier Technology (F.R.A.T)
"Brand Name" Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
F-BASS Remote Controller Compatable (Not included)
not mentioning name, these came off the website.
edit- i trust the brand, i have friends with this brand, but as soon as i say it, it will be blah blah.
When strapped, they are probably not stable at 1 ohms.
Similar to the Kicker SX series.
- SX1250.1 is stable to 2 ohms when strapped.
- SX650.1 is stable to 4 ohms when stapped.
Each FJL-1611d is rated the following at 1 Ohm load:
12.6V - 1250W RMS
14.4V - 1600W RMS
...it's in the product manual on Fusion's web site.
It is a two channel amplifier, and doesnt list a 1 ohm rating... That means it is not 1 ohm stable. It does, however, do its highest power rating bridged at 4 ohms; and if you have a setup that can be wired to 1 ohm then it probably can be wired to 4 ohms also.
If it is for a substage, I wouldnt reccomend it. Multiple channels are not needed, and the technology used for them is generally less efficient than a class D single channel amplifier.
I would be willing to pay under $200 for an amp like that...
You strap 2 of them together! Just like Kicker SX mono amps. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
mini-goog
mini-goog
Louisiana
DejaWiz
