Acizzle423
Basically, to make it short and simple. I have a Ranger ext. cab. My wiring from the battery runs behind the rear seats. Basically I was looking over my work. Cut on the H/U and start smelling a burning smell. I immediately cut power to the H/U and unplug the door speakers, initially thinking this was the problem. However after further inspection I saw a small line of smoke coming from the red power wiring. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Anyways, I inspect it and see that the 0/4 wiring is actually making contact with the metal on the seat/frame. I'm not too savvy on wiring, etc, but I put some duct tape around where the wiring has been damaged. The way the body shop ran it is behind the backseat yet through a bracket that opens/closes the seat, so I'm assuming that all the closing and opening of the seat stressed the plastic(w/e it is that surrounds the wiring) to the point it stripped(so to say). Should I be safe with the electrical tape covering it? I'd like to take it back to the shop, but this has been over a year and I have no receipt or anything.
Another question is when my first H/U was installed, the jackass who did it cut the factory harness. This has been over three years ago but I'm actually just now wanting to actually fix it. Basically when the asshat did it he cut my harness(claiming that he knew what he was doing, not sure on that. He could have done it on purpose or just a honest mistake). Either way my factory "alarm" doesn't work correctly and my power windows will open even w/o the ignition switch on. I also believe this is somehow got the electrical system still pulling a current while the truck is off due to the fact I've been through quite a few batteries. Is this something I could possibly fix myself or is it a bigger issue than that?
