Sold External voltage regulator, amps, headunits, F/S
Tacosys
First up I have an external voltage regulator. You can adjust your voltage from 14-20 volts with just a turn of a knob, its brand new and never used $115. Next up is a XSite XAD2K 2000 Watt Mono Amplifier. Its is almost mint condition, have some very light scratches on the front. The cheapest I can find one online is $489, this one was used for less than 5 minutes, comes in its original packaging, so I will ask $300 obo for this. Last but not least is a Fusion FCD245S, it is also BNIB has has the 40 second antiskip, great for bassrace or db drag, $210. All prices are obo, if you are going to lowball me don't bother. Here are the pics:
Fusion FCD-245S (Silver)
Internal Audio Amplifier MOSFET 50W x 4
Auxilary In
Electronic Subwoofer X-Over
Electronic Front/Rear X-Over
40 Second Electronic Anti-Shock
IR Remote
Motorized Faceplate
Detachable Faceplate
ISO/DIN Mounting, with Removable Trim Panel
2 Color Illumination (Amber/Green)
Marine (Corrosion Protected)
Telephone Mute
RCA Pre-Out
CD Audio/CD-R/CD-RW Playback
CD Changer Controller (6-disc)
Clock (12H-24H)
Internal Amplifier ON/OFF Function
Subwoofer Gain Control 0dB - +20dB
Subwoofer Pre-Out
4-Volt Pre-Out
F-BASS (Fusion Bass) 3 Stage Bass Enhancer
DVD Changer Controller (10 Disc)
D.T.A. (Direct Track Access)
CD Text Available
1 x 2000W @ 1 ohm
THD: 0.05%
S/N Ratio: >100dB
Freq. Response: 25Hz ∼ 200Hz
Dimensions: 17.71" x 10" x 2.17" (45cm x 25.4cm x 5.5cm)
http://ampguts.realmofexcursion.com/XSite_XAD2K/
Designed For Extreme High Amp Output Alternators, Used With Externally Regulated Systems with Conversion Regulator.
Features:
Self current limiting to protect against intermittent short circuit
Load dump protection against abrupt full load to no load
Extra filter networks to protect against voltage spikes
Adjustable voltage potentiometer
Reverse polarity protection
Epoxy encapsulated to protect against moisture and vibration
Positive or negative ground system compatibility
All connections to external terminal
All silicon transistor design complies with federal specifications
Certified burn-in cycle qualified
Adjustable voltage (14-20V)
Compatible with 8A rotors
Remote mount potentiometer
will that regulator fit any alt?
Yes its universal on high output alternators. I highly doubt you can wire this to a stock alternator though. It has 3 wires you need to connect, a positive, negative and the field. Its that easy.
could the external reg be used as a step down unit. say if i have my alt put out 16 volts going straight to the batts in the back and the reg step the voltage going to my car batt up front for my normal car electronics so i could have a 16 volt system and my normal 12v for my car all out of 1 alternator
No the regulator is what controls the output of the alt.It has to be hooked up via the field wire to the alt.A step down is different.
That ext regulator has to be used on an alternator designed to be ran with an external reg alt.
It appears to be a 911 regulator, which stems from them being used in emergency vehicles, but im not sure on that part. Ive had 3-4 ext reg alts and all of them used that one so compatability with any ext reg alt shouldnt be a problem.
Hope that helps
Hope that helps
Yep. Its for H.O alts only. I can't believe someone hasn't snatched this up yet. Remember guys I am open to all offers!
I bought a 250amp alt, and it doesnt seem to be an external regulated one, but was sort of cheap in price, you think I could bump my alt to put out maybe 14.7 volts, mine only puts out about 14.2 give or take a point or two. Want to stay in the stock class, but it seems my alt doesnt want to stay up in volts once it gets warm or hot. Maybe bump it to 15.5volts so when it gets hot it'll settle at about 14.5? I have an epic 160, a few different size fuse holders(2/0, and 2gauge), and a very new 18volt drill with charger. a couple of webcams. and an extra 40 gig hard drive (internal) for a PC.
Oh yeah, whats a "field" you said it connects to the field.
When you upgrade your existing alternator you shouldn't need to upgrade your
voltage regulator. When upgrading to a high output alternator you rarely need
to change your voltage regulator. The voltage regulator controls the alternator
output by sending power to the rotor (field). The rotor spins inside of the stator,
the reaction between the rotor & stator is how power is induced within the stator.
The voltage regulator senses the battery voltage, if the battery needs more power
the voltage regulator sends power to the rotor coil turning the alternator on. If the
regulator senses that the battery or system needs a lot of power it sends maximum
voltage to the rotor making it a big electro magnet thus causing the alternator to produce
maximum power. If the regulator senses a small need at the battery it will send minimal
power to the rotor causing the alternator to produce little power. Never
does the alternators amperage go through the voltage regulator. The area of
concern when changing to a high output alternator is the amperage draw of the
rotor. The voltage regulator does have a field amperage rating and because it
has direct contact with the rotor you must be concerned with the amperage draw
of the rotor. If the amperage draw of the rotor is greater than the rating for the
voltage regulator the regulator will fail.
Tacosys
Tacosys
Cincinnati
Tacosys
