Sold External voltage regulator, amps, headunits, F/S
Tacosys
First up I have an external voltage regulator. You can adjust your voltage from 14-20 volts with just a turn of a knob, its brand new and never used $115. Next up is a XSite XAD2K 2000 Watt Mono Amplifier. Its is almost mint condition, have some very light scratches on the front. The cheapest I can find one online is $489, this one was used for less than 5 minutes, comes in its original packaging, so I will ask $300 obo for this. Last but not least is a Fusion FCD245S, it is also BNIB has has the 40 second antiskip, great for bassrace or db drag, $210. All prices are obo, if you are going to lowball me don't bother. Here are the pics:
Fusion FCD-245S (Silver)
Internal Audio Amplifier MOSFET 50W x 4
Auxilary In
Electronic Subwoofer X-Over
Electronic Front/Rear X-Over
40 Second Electronic Anti-Shock
IR Remote
Motorized Faceplate
Detachable Faceplate
ISO/DIN Mounting, with Removable Trim Panel
2 Color Illumination (Amber/Green)
Marine (Corrosion Protected)
Telephone Mute
RCA Pre-Out
CD Audio/CD-R/CD-RW Playback
CD Changer Controller (6-disc)
Clock (12H-24H)
Internal Amplifier ON/OFF Function
Subwoofer Gain Control 0dB - +20dB
Subwoofer Pre-Out
4-Volt Pre-Out
F-BASS (Fusion Bass) 3 Stage Bass Enhancer
DVD Changer Controller (10 Disc)
D.T.A. (Direct Track Access)
CD Text Available
1 x 2000W @ 1 ohm
THD: 0.05%
S/N Ratio: >100dB
Freq. Response: 25Hz ∼ 200Hz
Dimensions: 17.71" x 10" x 2.17" (45cm x 25.4cm x 5.5cm)
http://ampguts.realmofexcursion.com/XSite_XAD2K/
Designed For Extreme High Amp Output Alternators, Used With Externally Regulated Systems with Conversion Regulator.
Features:
Self current limiting to protect against intermittent short circuit
Load dump protection against abrupt full load to no load
Extra filter networks to protect against voltage spikes
Adjustable voltage potentiometer
Reverse polarity protection
Epoxy encapsulated to protect against moisture and vibration
Positive or negative ground system compatibility
All connections to external terminal
All silicon transistor design complies with federal specifications
Certified burn-in cycle qualified
Adjustable voltage (14-20V)
Compatible with 8A rotors
Remote mount potentiometer
Will do $200 shipped on the HU, and $100 on the voltage regulator. I am taking a loss on both of these but I need the cash bad //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i know this might be a dumb question, but what else do you need to run a system at 16v?
can any alt run at 16v with a voltage regulator to say so and is it "bad " for the alt to do so?
explain what i would need, please. a 16v alt?
If you want a 16v setup you will need 16v batteries of course, also you will need a step down module to run your regular car accessories off of, like the headlights, ac, everything.
Tacosys
Tacosys
Cincinnati
Tacosys
