expert advice please!!!!! speakers for 2016 tacoma double cab
  • 5
im referring to modifying your EQ and gain to match the new headunit output.. not familiar with the ms-8 but i assume you'll need to modify gain if the input signal is increased thus increasing the dsp pre out signal.
Not with the ms-8. Once it sees a clean input it does everything. Wipes out everything. It has its own pre amp
---------- Post added at 02:26 PM ---------- Previous post was at 02:26 PM ----------
1. so if you were buying speakers 6.5 components and 6x9 coaxial for 300 per set which would you buy?2. is there a amp made that has the adjustability as a bit 10 that i could buy in the 3-400 range
Answer number 2. Not even close
Sounds like me ...i should saved all those yanked Bose amps ithrew in the trash ..i couldve retired off ebay from them now .....lol
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
579
It also lowers the amps efficiency and raises the current draw.
712
884
kkjjjmccann
kkjjjmccann
maryland
disturbed471985
