expensive wire or cheap
not necessarily
wire is generally wire, the main difference is thread count and covering/shielding. i can almost gurantee you wont notice an audible difference in the .69/ft and 2.00/ft wire
not necessarily
wire is generally wire, the main difference is thread count. i can almost gurantee you wont notice an audible difference in the .69/ft and 2.00/ft wire
but it says kicker on it!!!!! that makes it x4545454 better //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Copper is Copper. The main difference between cheap quality wire and expensive quality wire is the strand count (makes it more flexible) and possibly the quality of the insulation.
However, wire is not wire. Go too cheap on the wire, and the actual diameter of the copper is reduced, and the wire uses a thicker insulation jacket so that the outter diameter is relatively the same. It is possible to find cheap "4ga" wire that's actually only as thick, copper wise, as standard 8ga wire.
So yes. Copper is copper. But wire is not wire.
marcusb419er
was from oh but now in fl
dkguitarist
