exodus anarchy 4 ohm
cal
exodus anarchy
8 ohm Specs:
Fs = 45.8HZ
Qes = 0.48
Qms = 6.37
Qts = 0.44
Vas = 9.61L
Sd = 131cm^2
Xmax = 12.5 mm one-way
Re = 6.4 Ohms
Le = 0.84 mH
BL = 10.79 N/A
Power: 125W Approx: No IEC testing conducted
Spl = 84.7 dB/1W/1M
specs are for the 8 ohm model only difference is mine are 4 ohm
7" driver
mounting depth 4"
overall diameter 4.25
new never powerd them or installed all i did is made a mdf ring and tested the fit so there are marks on the basket as seen in pics .
125 shipped for both con u.s.
only trades are for sundown 4 ohm neo pro 6.5
God I want these. Sure you don't want to trade for a set f alpine SPX17PRO woofers? Excellent shape.
i have no use for a set of woofers alone and to be honest would be harder to sell them than the anarchy .
It also lowers the amps efficiency and raises the current draw.
461
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
299
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
993
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
cal
cal
cal
    May 16, 2024
    May 16, 2024
