exodus anarchy 4 ohm
cal
exodus anarchy
8 ohm Specs:
Fs = 45.8HZ
Qes = 0.48
Qms = 6.37
Qts = 0.44
Vas = 9.61L
Sd = 131cm^2
Xmax = 12.5 mm one-way
Re = 6.4 Ohms
Le = 0.84 mH
BL = 10.79 N/A
Power: 125W Approx: No IEC testing conducted
Spl = 84.7 dB/1W/1M
specs are for the 8 ohm model only difference is mine are 4 ohm
7" driver
mounting depth 4"
overall diameter 4.25
new never powerd them or installed all i did is made a mdf ring and tested the fit so there are marks on the basket as seen in pics .
125 shipped for both con u.s.
only trades are for sundown 4 ohm neo pro 6.5
God I want these. Sure you don't want to trade for a set f alpine SPX17PRO woofers? Excellent shape.
i have no use for a set of woofers alone and to be honest would be harder to sell them than the anarchy .
cal
cal
cal
