Excursion System Rebuild
Ok,
So I have taken the past few days off from building the X to do a little side project I had.
We have an RV that has had a piss poor stereo for awhile now. So it's was time to upgrade a little. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Some of our out of town shows we drag it out to chill and BBQ at shows.
This had to go
I had this laying around so it went in as well as an older navi, An Ipod adapter and a Sirius tuner
Then I decided we needed to have a little tunes for outside.
I just go started on the wiring.
I picked a roll of Shok Wire for the job.
And thats all I have for pics. I had just about all the power wire finished off when I split my head open on one of the open doors and put a 2" gash in muh head. So a handful of stitches later, I don't feel like doing shit for a couple days. So when my head quits pounding, I will get back to this and the X build.
It's CCA, So I would say it's current carrying capabilities are a little less then Copper of the same strand count. However I would feel confident using it in most daily systems. I have about a 40ft run, once I get back into the building spirit i will do some testing to see if there is a power drop in that distance. I doubt it will, but it's a good system to check on with.
The wire itself is some of the most flexible I have worked with.
I've tried to look into shok wire and can't really find anything on the internet, do you have a website or something for it, it does look good.
I'd love to see how this RV turns out, I always thought it would be neat to see what an RV system would be like.
Thanks for the kind words guys.
I should be knockin out the RV this weekend.
I'm sitting here ordering up some small stuff for the X as I type. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
how would you wrap something like that with the changes in height of the door and curves and such?
It's not easy.
That inner curve is a *****.
It takes a really good glue, A good heat guy and a very high quality material.
It also helps to do this during the warmer months, not in the chill like we are //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
I spent a little time on this again today. Finished off the wiring and ran the RCA's
The fuse block was a little disappointing. Sure it looks nice, but the performance sucks. First all all the display has a loose connection so it's displays intermittently. The overall function of it works, so I will leave it for now. The other thing I didn't care for was the blown fuse alarm. So unless you use all 4 fuses or in my case at least have all fuses in, it will beep at you.
I have an idea for the speaker connections that I will have to search out for part tomorrow.
Kingsuv
Kingsuv
Sacramento, CA
Brian_smith06
vegang
vegang
