Enclosures
Bandpass....are you talking a enclosure such as this....
or ported such as this...
And i know they prolly do not look just like those but...thats all i could find for pics in a hurry...
Also what subs? Space available?
Thanks
AC
thats not even what my question was moron. It was between bandpass boxes and SEALED BOXES. wether u can really tell the difference in sound in a trunk.
There wil be a big difference in a couple of ways.
with a bandpass box if designed correctly for your subs. You would have a big increase in output around the tuned frequency of the box. But not a very broad range. Good for rap, and competing if designed correctly
With a sealed box you would have less output. But a much broader frequency range. And much more linear output. Good for jazz, rock, pretty much what have you. Sealed also gives you a tighter sound overall.
Originally posted by scott4251 thats not even what my question was moron. It was between bandpass boxes and SEALED BOXES. wether u can really tell the difference in sound in a trunk.
ya, i know what the question was BUT...he did not identify what he was talking about... a ported box is a bandpass box...a "bandpass" box (with the plexi) actually is a dual bandpass box but is just commonly refered to as bandpass.....
ported is better...bandpass is boomy
ahhhh....ok...
i am going to give up //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Anyway, my opinion is that a ported box tuned to around 30 - 35 hz will play as well as a sealed box but will get louder.....there will be a slight loss of low low but a box tuned to this is likely to peak at a range where most bass will fall...and i know this is not all bass but...in my opinion porting gets louder overall...
Hope i am still not pissin anyone off
AC
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
scott4251
scott4251
Michigan
debonaire
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
