Enclosure Specifications for AB XFL 12's?
  • 5
anywhere from 1.75 - 2.5cf depending on power and listening habits
I have mine in a 2.25cf enclosure tuned to 32hz, straight smashing 26hz on a CT Sounds 1400.1 (Around 1800 watts rms), and the subs never gets hot, bottoms out, or anything. XFL's really are some bad *** subs man
I agree had mine in 2cubes at 32 hz on a kicker kx2500.1 and I would be straight brutal from 28-60hz.
I'll have to put them in a sealed box unless I can figure out a way to build a 5 cube box that's less than 13.5" tall x 36" wide that I can slide into the trunk through the back seat. I just finished a 4.3 cube box tuned to 32 he that I can't get into my trunk! Doh!! It was good practice for the next box.
You should be able to get 4 cubes after port and displacement with your measurements. That all you need for a pair if xfl 12s
Excellent! If I build a new box that's 13.5 x 36 x 36 where would the port go and how would it look to tune it to 32 hz? The only reason I was able to build the last box is because I found the schematics on the r/t site. I really have no idea what I'm doing =)
Maybe I could do an Aeroport? I believe I might be able to make a smaller box and use one of those? I'm not really sure if that's the way to go or not but it's an option I think?
I have box specs on my note pad subs back port back
Does this mean you just wrote it out on a sheet of paper? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Or is there a link to this box online somewhere I should check out?
I'm old school. It's at home in my box design pad. Yes on a piece of paper
OK, I gotcha. Well, when you get home would you be so kind as to post some measurements here??? I've been browsing through Google for similar boxes and came across this thread in which a guy wrote...
" 13.5"H x 36"W x 24"D, from 3/4" MDF, this will put you at 5.391^3ft gross. Build a single slot port, 12" x 4" x 19.5"Long tuned at 35Hz. After displacement you will be at appx. 4.533^3ft net vol."
Now that may be a bit on the large side but after sub displacement it might be perfect for those 2 subs. I'm not sure if the above measurements are including the slot port or if it's the 5.391^ft before the port? I'm also curious if he's just talking about one single baffle that's 12" tall x 19.5" that is 4" from the side of the box?
If these measurements are close to what the AB XFL 12's need then I like the idea of having only a 24" deep box, I may get some trunk space after all //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif However I'm not sure how to tune it to 32 hz instead of the 35 hz he has in his design.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
618
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
FadedSpy
FadedSpy
Sioux City, IA
FadedSpy
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
