Enclosure for 2 x Hertz HX 300
Rian
Sweden
Hi!
I have 2x Hertz HX300 subwoofers and bought a cheap enclosure but it is a peak at 64 Hz and below almost nothing.
I'm going to build a new enclosure but the question is how it should be tuned for the best quality. Would love to hear a little more of the lower notes.
Any recommendations?
And I have a Volvo S40.
Thanks!
  • Hertz_HiEnergy_hx300.pdf
Tuned from 30-34 hz should work fine. You’ll need 2 cubes of air space for each sub also. You may be able to drop down to 1.75 cubes if necessary. If they were mine, I would do 4 cubes at 30hz for both 12s.
Sealed or Vented?
If you want strong lower bass, we could do a nice ported box. You can PM or email me, if you're interested. I need to see what space you have to work with, what types of enclosures we can fit. We could even do something like a 4th order bandpass, if you can fit it.
Those subs have a Fs of 33 hz, I can make them probably play into the high 20's, if you'd want to play that low.
It's all in the box design; bad box = bad sound, no matter the woofer. A well designed ported box will play very well and be loud. And if you tell me what sound you want, I can make your sub play it.
Ok I'm going to measure the trunk space today and I want a ported box for 2 subs and I what it tuned for the max quality and the most flat aptitude no peaks.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
595
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
Rian
Rian
Sweden
Rian
    Apr 26, 2024
    Apr 26, 2024
