Enclosure Build For Effect
DonH
So Cal
Ok enclosure build for Effect and his IDMAX 12"
Design is 2.5 ft^3 @ 30hz with 31.25in^2
Alright here is the design:
Sides will have carpet inserts //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif hence the over hang
First cuts tom. afternoon. stay tuned
cut pieces
Mock-up
port view
back setting but now done
more to come in about 15 mins!
side@1
double baffle cutout
I dont like those style of clamps with the pivoting head you have to be careful not to pull stuff out of square. Ive started using bessys from lowes, http://www.amazon.com/Bessey-KRK2440-Fixed-Parallel-Clamp/dp/B001HSO6V8/ref=sr_1_1?ie=UTF8&s=hi&qid=1241549887&sr=8-1thats a good set to get you started.
Build looks good too btw
I FEEL YOU MAN! thats why i make sure is square and constantly check on it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
up for pics!!
front
port pieces setting
all for today maybe some tonight have to much hw to do! and gotta work at 2!
so customer wanted it to be flush mounted.... here you go //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
another shot
up for pics!!
Bessey also has a corner clamp, like the one you have pictured (i have the same ones) but instead of two seprate screws to square it up it uses one to do it, makes it much easier. I personally hate those esp when your working by yourself with a big piece of wood.
so true man!
had a ***** of a time gettn the first cut done today //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
my lil table broke //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
DonH
DonH
So Cal
DonH
    May 18, 2024
    May 16, 2024
