Electrical ?
well see thats the thing, im pretty much moving around my electrical system right now on what im going to buy. so i was just seeing if you guys might now from wittnessing, i was thinking an alphasonik 3000 watt that will probably do 2300 and 2 wmd 12's or 10's
That should be good. Just make sure you have 1/0 wire ran and of course the big 3 done if it isn't done already. Also run the ground to the back to the amp.
Ok now we are getting somewhere i had that amp the alphasonik 1000hca right if so i highly recommend you get at least 2 deka 9a31's those amps **** up alot of current..Keep the volts up and you will like the amp..
Bassdude22
Gears 2 Pwner
Bassdude22
PA
Buck
