Electrical upgrade advice...
els1989
Minnesota
Vehicle in question is 04 GMC Sierra stock alt. knu 1/0 big 3 and single run to amp... Amp is orion xtr 2200 batt is xs power d3100 or 3400 can't remember picking truck up tomorrow from having tranny rebuilt
Had amp running 2 ohm around 1500rms par Orion's claims... Was getting some serious voltage drop even at speeds... Now those subs are gone with 2in seat lift soon to go in(if machinist has them done yet) gonna have stang custom build box for 2 sundown x 8's with Baltic and a etched plexi lid or side... intentions of running 1 ohm...
Thoughts of dcpower alt, or second battery probably both... Maybe even dual alt... But I don't think that would be necessary... Thinking of adding just a twin batt in the front somewhere, not sure exactly where to locate it or where to find a mount set up, also upgrade to spi 320 I believe idle amp at 240 and 220 hot...
How much power could this setup handle? Any alternative ideas? Also retune my amp with my dd1 and possibly loose the remote knob.... Seemed glitchy would go from little bass all the way down to partial turn let's say 45 degree turn to crazy loud difference
Helpful advice apreciated
Yea, one alt should be fine.
If you park and pound a lot, get a hairpin, because they produce more power at idle than conventional. If you listen while driving most of the time, a conventional is fine
So I'm not crazy for just running one batt. Lol a co worker was trying to tell me idk what I'm doing because I'm only running one battery lol I'm only running 2.2-2.5k rms now if I was running 3.5-5 k rms and still trying to run battery I would agree with his statement .. He's my supervisor and his so called amazing system he had was powered by a hifonics
If I add a second battery even if it was a lower powered one but still a xs so the resting voltage stays the same wouldn't that take a load off of the alternator or will the alt still be worked as hard?... If I'm gonna buy a 8hundo alt want it to have a long life
Yea im mostly likely going to go that route. Dont plan on winning competitions or playing full tilt all the time. I watched some good videos last...
10
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
els1989
els1989
Minnesota
els1989
    May 12, 2024
Brendon Jenness
    May 11, 2024
