Electrical Help Please!!!!!!!
SouthRuninIt
Okay I have the following
Head Unit : Pioneer 9800bt
Highs Amps : Concept CCD-2400 (2)
Tweeter Amp : Legacy 1200
Sub Amp : Hifonics BXi2006d (2)
Clarion Crossover
Orion MaxxBass
Okay I need to know what all might I need to keep everything up and running and getting all the volts required and keep my lights and stuff from dimming... The car is a 2000 dodge stratus so far I have a hell of alot of "0" gauge wire and a red top optima battery, now I know Ima need more stuff so just tell me if thats not a problem THANKS:) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :)
would not use a red top for audio.....
I was going to put that one up under the hood but I havent used it yet so I can always take it back... and I have been reading the post on HO Alternators and Ion kno if I wanna take that chance of my car fvckin up ya dig
Our 87 Porsche 944 has the battery located against the firewall, in the corner near the hood shocks. Not only is it there, but the positive terminal is against the firewall too!
Same thing with my 88 wrangler I had. Battery in same spot, positive against firewall.
What the hell are the manufacturers thinking?
See my battery is a side mount and the terminals are pointing towards the tires so I mean its kinda hard to put a lot of wires down there... so how might I do the big 3 on my car
Hmm where there is a will, there is a way. My alternator is on the bottom of the engine.
I can put the alt. in but how would I go about doing the big 3 wit the tight places I have to work with... like I have heard Ima have to do multiple runs of 0 gauge wire to the trunk but how could I do that wit the position of my battery
I don't see what your exact problem is. Is it getting to the battery terminals? If so, it is possible to get to them, your battery has been replaced before, I'm sure. Get your wire, go out to your car and plan how you are going to route the wires and what to zip tie them too. And then do it!
Okay now after I do the Big 3 then what else do you think I will need like how many batt's and what size alt. and would I need a cap, an isolator, batt relay, or what thats what Im trying to find out and then like how many runs of 0 gauge will I need
i do believe a kinetik 2400 fits up there if it does you should be ok
Okay so get one of those and get another one to go in the trunk, do the big 3, and what else???? Im trying to get everything done be4 this saturday because its our homecoming
SouthRuninIt
SouthRuninIt
Alabama
SouthRuninIt
