electrical good enough??
I notice I find questions like this on here a lot (can my alternator handle ____)
The math to figure out your draw is as follows:
Current = POWER (watts) ÷ Voltage
So typical, and assuming you mean 2000wrms
2000 ÷ 14.4v = 139 amps of current draw
Now 139 amps is just from the amp, not including what ever other devices/vehicle usages you have.
Granted, "The Big 3" helps a lot.
this is a ballpark number as there are efficiencies to look at from the alt and the amps
This is true, but it's also a great start.
Not really. There are too many factors to include when talking about current draw. Music is dynamic, efficiency, an imperfect ground, gain, etc.
Most of the time you're not seeing even half the max current draw from an amp.
2000 / 12 = 166A, add efficiency of 80% bumps it to 208A.
Now, if you listen to bass heavy music, then you could frequently see 100+ amps of draw.
You'll need a 2nd battery and the big 3.
I guess in a way that’s what I was trying to say... but just couldn't put it into words. Most of the people I personally know with systems all pretty much listen to rap, and most go for SPL over SQ. I know the mathematic equation is a ballpark number, but usually gives a decent place to start looking from while adding everything else into play
Max4hdmatt
Max4hdmatt
Bear, DE
Tragic00
