Electrical Buzz in rear
kravits88
CA
The problem I am having is that when the car is started there is a high-pitched constant buzz that can be heard, it is not extremely loud but can easily be heard. It started fairly randomly and I had thought it was my head unit until recently when I had it was replaced and the sound was still there. The sound does not start if the car is only turned on to the first start position so just the stereo is running but will sound if 2nd position is switched on although the car doesn’t need to be running. I was told to check my rear speaker connections but can't see any problems there. Any information or help would be greatly appreciated. Thanks.
Sounds like a personal problem, but don't worry the batteries will die eventually.
ON topic, are you just running them of the stock wiring from the Head unit? Or is there an amplifier involved?
If you're just coming off the head unit, try hooking a (different, can be a cheap POS, whatever you can get your hands on) speaker up right off the head unit wiring. If there is still a buzz it's probably a shitty ground for the headunit.
kravits88
kravits88
CA
UndercoverPunk
