el cheapo fuse holder
how much water gets under his hood when he drives in the rain? that fuse holder would probably work, but it would be a good idea to wrap tape around the wire at openings to create a better seal if the wire is too small. i wouldn't use silicone because then you'd have to re-silicone every time you blew a fuse.
yea we slapped on in there hasnt given him anytrouble eeven with a ton of rain the last couple days.
water gets into the engine compartment when it rains? man u got a leaky car
not really leaking in just coming up from the road while driving in the rain and such
Sounds like a plan.... but really, how often do you blow a fuse ? I've had car stereo stuff for years and not once have I blown a fuse. What am I doing wrong ?
Ive blow lots of AGU fuses because my local shop mixed up a bunch of 40's with the 60 amps. Dumbasses.
BTW your not doing anything wrong unless your using fuses that are way too big. Like a 200 amp ANL fuse for a small 50x2 amp.
kingpin_jeffie
i need a vacation...
kingpin_jeffie
Erie, PA
kingpin_jeffie
