It means that, with a few grand of processing (in a studio, not a car), a decent amp can be processed to sound like a "high-end" amp.
All RC adds to the signal chain in a solid state vs solid state amp comparison is an equalizer, if one is needed. Which anyone can pick up at their local dealer for a few hundred bucks. And all he adds to the solid state amp in a comparison against a tube amp is a resistor on the outputs of the SS. Not sure where this few grand in processing you claim comes into play.
And you can perform the experiment in your vehicle for the challenge if you wish.
Richard Clark's test doesn't prove that an RF amp replacing a Brax amp with no processing will sound the same, rather that it can sound the same with the right processing.
And "the right processing" would be an equalizer (if necessary), proper gain adjustment, and keeping the amplifier below audible distortion levels.
I don't know why everyone wants to make it sound like RC performs magic on the amps in his experiment. All he does is set the amplifier's gains identically, not allow you to exceed 2% THD, and equalize the frequency response where/when necessary. Stuff that
anybody can do in their own systems. And really stuff that everybody
should already be doing for the most part...but unfortunately most do not.
I do not see the value of this test in a car environment, where the processing needed would cost more than the high-end amps.
His experiment provides very valuable information. It proves what differences in amplifiers are and are not audible. I'm still not sure why you think the processing needs to cost thousands of dollars. We are talking about an amplifier and a DMM for the most part.
Which is more cost effective for the same net results....a $300 amp and a $200 EQ, or a $1000 amplifier?
If you don't see the value, then I don't think you fully understand the test and what it's set out to prove. Not that a watt is a watt, or that all amps sound the same (though the vast majority will have zero sonic differences when set properly). But that two amps that measure the same (within inaudible tolerances) will sound the same. And if the addition of something as simple as an EQ (if necessary) will allow that cheaper amp to "sound" just as wonderful as that expensive high end amp....how is that not valuable information?
And what I wanted to add before my PC f
ucked up on me ( //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif ).....Basically what RC has said, and setup an experiment to prove, is that the "sonic characteristics" of any power amplifier can be summed up in the classical measurements of power, gain, frequency response, distortion and noise. His experiment (challenge) was setup to test the hypothesis that two amplifiers of equivalent actual power output, with equally set gains, distortion and noise below audible thresholds (distortion > 2% THD, which almost any amp should be able to do), and with inaudible differences in frequency response will sound identical. And so far,
no one has
disproven this. Which means that if you have two amplifiers, with equivalent power, equal gain settings, and inaudible differences in frequency response, distortion and noise....they
If an amplifier is not capable of producing inaudible distortion and noise...then that's not an amplifier worth owning anyways since any decently designed amplifier should be able to exceed this requirement easily. So that's an easy pass, and a lack of sonic difference. And since it's not hard to find two amplifiers of equivalent actual power output, and
shouldn't be hard to set their gains identically......this leaves us with frequency response. Which,
even if there is a small difference in the frequency response of two amplifiers...this is not hard to correct with the additional of an equalizer. But in most cases, even this is not necessary. But if it is necessary......I don't see the reason why it isn't valuable to know that, for example, a $300 amp plus a $200 EQ can "sound" just as great as that $1k+ amplifier at less than half the cost //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
