dynamat on the inside of box....
Erm, well first no one can see the inside of the box, second, sound deadening is used to keep sound waves in, and to rid of rattles, two things the mdf doesn't have a problem doing. All it would do is take up space.
GOOD ANSWER! //content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif
yeah that was exactly what i was thinkin, the only reason i was askin, was becuz on pimp my ride, they always put dynamat on the indisde of there plexiglass boxes, but i didnt know if it was just for looks or not.....
Actually, i think if it takes up space it would lower your tuning.
Smaller box and the same size port=lower tuning. No? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
if your port size/length is constant, but the box size decreases, the tuning goes higher.
First off, do not base your stereo design/choice off of what you see them do on "Pimp my POS". They appear to know about as much as ass hair about stereos.
But, they plexi isn't nearly as strong as MDF. You need really thick plexi to get much strength from it (which isn't cheap), so they are probably using some fairly thin/flexible crap, and so they use the sound deadening to help reduce some resonance problems with the box.
Isn't this useful if the box is made of fiberglass rather than MDF, though?
What, sound deadening? Fiberglass can be just as strong as MDF if the box is constructed properly. 'Glass is extremely strong when curved, and rope and such can be added to help strengthen the flat surfaces.
They do that to the fiberglass because it sometimes is prone to rattling. If you have a fiberglass box you are most likely not going for SPL, so they are probably going for show or SQ, and the box is sealed so when they put the dynamat on it, it keeps it from vibrating and it may actually help to stiffen the glass.
So is there no reason to spray rubberized undercoating inside a fiberglass box, or line the sides with modeling clay, or apply deadening material, or any of a thousand other ways to manipulate box resonance, if it was built properly? Because I’ve seen all of these done and recommended.
I’m building my first glassed box, and don’t really know if it’s constructed properly or not (due to lack of experience). I will have finished putting about 10 layers of Bondo brand mat down soon, and it still will just barely be ¼” thick (which many people consider too thin, apparently)… so I’m not sure if I’ll have to be one of those who will have to slap something on the insides to compensate for poorly-built box. This was why I was wondering.
It completely depends upon how thick you make it. If you don't have enough layers of 'glass, then sure it's going to be weak. And as I mentioned, you can lay ropes and such inbetween the layers to strengthen the 'glass. If anything, bracing it would be the best way to go.
The spray-on undercoating I seriously doubt will be heavy enough to do anything. But, Read This, pay close attention to Dan Wiggin's posts, and it should give you a good idea of the best ways to go about it. The thread is aimed towards kickpanels, but the same concepts can be applied to sub enclosures. Notice what he says about what is required to change the resonance
waNtsumBuMP
NOR CAL BEATZ
waNtsumBuMP
Granite Bay, CA
rx7vert
