Dual voice coil wiring
Hydrogen
Hello, I'm currently ordering a new subwoofer for my system, it's a Ground Zero GZRW 12D2.
I'm using a Ground Zero 2155X amplifier which is underpowering the sub but it isn't a matter because I will be getting a new amp soon.
My question is, the sub has 2x 2Ohm coils. My amplifier can put out 100W each channel at 4Ohms, 150W on each channel at 2Ohms and 300W-400W (?) bridged 4Ohms.
Do you think I should connect one coil to one channel, other to other with a mono signal so both outputs are the same and don't destroy the subwoofer or just put the voice coils in series to get a 4Ohm load and bridge it?
Thanks for the help.
Hydrogen
Hydrogen
Lithuania
garychoffmann
