Dual voice coil wiring
  • 2
Hydrogen
Hello, I'm currently ordering a new subwoofer for my system, it's a Ground Zero GZRW 12D2.
I'm using a Ground Zero 2155X amplifier which is underpowering the sub but it isn't a matter because I will be getting a new amp soon.
My question is, the sub has 2x 2Ohm coils. My amplifier can put out 100W each channel at 4Ohms, 150W on each channel at 2Ohms and 300W-400W (?) bridged 4Ohms.
Do you think I should connect one coil to one channel, other to other with a mono signal so both outputs are the same and don't destroy the subwoofer or just put the voice coils in series to get a 4Ohm load and bridge it?
Thanks for the help.
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
755
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
772
Hydrogen
Hydrogen
Lithuania
garychoffmann
slater
    May 2, 2024
slater
    May 2, 2024
