Dual DD512 common chamber question
Building a new box for my two DD512 for my daily 2002 accord 2dr
will be powered by a powerbass 600.4x for now
3.95^3 ft after displacement
how will this box do for SQ and SPL mix more SQ though
thanks for any input
dd for sq tho?
true! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
but im not looking to win any comps with them so this set up would lean more to the SQ side i guess but i know they will still put out very good lows
i have a DDLE12 in my GF tacoma on only 200w from a jensen LSA600 //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif& it does pretty good nowhere near what it can though
i used DD website for port area and box volume but jack at DD said to run a 22" port my ? is: is that 22" per sub or 22" for the whole box
This box should get the job done for you. Its 4.25cuft tuned to ~35hz w/ ~14sq per-cuft port area...it will be fine w/ those DD512's.
External measurements are 31.5 x 15 x 24. Port is 4.5w x 13.5t and actual length is 24". Make sure you put a brace between the subs, a 3.5-4" brace will do. Wedges in the back corners will help also.
that looks good but i want to do a dual port b/c im going to flush mount the subs with a face board to cover all the amps, wiring ect. something like this
but ill cut out the area for the ports or would areos be better for this setup
so should i just do (2) ports 2.25w and 12" long
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
bad03ranger
