Dual battery wiring tutorial (and why)
I have a couple of possible issues. The batcaps terminals are like set in, which means I would have to bend the bus bars to be able fit them down in the terminal. You see what I'm saying?
then use short 1/0 pieces. i'm not familiar at all w/ batcap
edit: yes. go with that.
hold up...
inset like this?
just turn them to face each other and bolt that **** up.
edit, that wouldn't work. they would be on opposite sides //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
you could def bend them. but have fun w/ that.
And it would be easier than having like 4 ring terminals on each battery. What If I did a bus bar, but not on the battery? Like I ran some runs of 1/0 from the 2 batcaps to a bus bar that is fused?
looking at that, could you not use a bit longer bolt with washers to compensate and just go right over the top of them?
like this:
bolt -> bus bar -> washers (to fill the gap) -> batcap.
like this:
Ya I guess I could. I just haven't messed around with it yet. I'm just thinking, it would be best to use copper materials, right?
531
699
999
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
935
loopkiller
PERMA-BANED
loopkiller
Glass City
Dxtr315
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
