Dual Battery Question. Already Searched
Scoobasteve
Hi Guys,
I have a 1999 Civic SI, with a 165a alt and a yellow top under the hood. Big 3 has been completed with 0ga wire.
I'm planning on running a
Alpine MRV-F545 4 channel (fused at 80a)
and
MTX 7801 - 150a i believe.
My question is
If i run the yellow top under the hood and a Kinetik HC2400 for the trunk do i have to run the negative cable from the yellow top to the kinetik or can i use a chassis ground in the trunk as the yellow top is grounded directly to the chassis under the hood.
Or would i be better off running a distro block under the hood and the HC2400 as my main battery.
Thanks,
Steve
Just make sure you use the same gauge wire to ground both front and rear battery. 1/0 would be recommended throughout that install. Also you "should" fuse the main wire 18" from both battteries to keep power out of the cabin in case of accident. One Fuse holder will not protect the car with the second power source now in the car, either use two fuse holders or none at all.
Scoobasteve
Scoobasteve
Mississauga
bad_trip
michigan born
    May 14, 2026
michigan born
    May 14, 2026
